Removing wall breaks
             Tool  |
             Tool set  |
             Remove Wall Breaks
             Building Shell  |
The Remove Wall Breaks tool cleans up any wall breaks or gaps that were created during editing. For example, if you create a new wall that joins an existing wall, and then later delete the new wall, a break in the remaining wall displays at the joint. The Remove Wall Breaks tool removes the break and any end caps.
To remove wall breaks:
Click the tool.
Alternatively, right-click on the wall and select Remove Break from the context menu.
Click and drag to create a marquee box around the wall break or end cap to remove.
The wall break or end cap is automatically removed.
